How can I show
year ,
sales revenue ,
sales revenue (where lines inlist “accessories”, “city skirts” ) ,
sales revenue not inlist (“accessories”, “city skirts”)
from the efashion univrese in a single table of a report tab.
Say I want to compare my sales revenue for a year based on lines like accessories, city skirts and the remaining lines.
*Note- Lines object cannot be included in the table.
I have customized this to satisfy a business requirement I have. I am sure anyone of you BOB’s have gone thru this. Advice please:
Thanks for the response but…
That option complicates a lot of things. Like if you wanted to show 5 columns with each having a different list criterion…would you go for 5 Dp’s?
It I guess is not a viable option.
Thanks again but the two options mentioned above I have tried and dont work. Reasons
The first option to create a measure @ the universe would need hardcoding and since I am dealing with transactional data thats not an option as I need the universe to be as dynamic as possible. So I got to do this @ the report level.
The second option for using where doesn’t work as where lets you use only = operation and one value only. I need to use != (not equal in a few cases) and match a list of values to the variable in some cases.
The third option where I use If then Else isn’t working and gives me an #Computation Error. I am trying to use = If =“France” Then Else 0. I get this error if I dont have the Country object in the table, but Once I pull it in I get repeated rows for year which I dont want to happen.
Have attached a report. Please have a look and advice.
Please, take another close look at the FAQ Reporter entry in my previous post, using the work around creating a boolean flag, which in turn can be used in the WHERE part of a report variable will work just fine.
