BusinessObjects Board
Dashboards outside SAP
I was wondering if there is a way to use the Dashbaords created with Dashboards 4 outside the Central Management Console or BI launch pad.
We are designing a new portal and we would like to use the dashbaords within our portal.
bas_vdl :netherlands: (BOB member since 2012-11-08)
yes, you can export it at flash format and put it anywhere. If the data are linked to database (using univers query or web service), you should create and configure a crossdomain.xml file
That will do the trick, thank you!
