BusinessObjects Board
Dashboards lookup y-axis min & max values when automatic
I have two graphs that I’d like to be set to the same range but the first one will show multiple series that can be turned off and on. I’d prefer that one to be set to automatic y-axis and have the second graph mirror the range and what not. Any suggestions or am I barking up the crazy tree?
Best,
J
jweitz (BOB member since 2013-02-25)
I don’t think it’s possible as you propose.
I’d say figure out a way to find out how many series are being selected, or even build you own structure for turning them on and off, and then set both ranges to the appropriate values.
Good Luck!
theknowtank (BOB member since 2011-04-20)
if i’m understanding correct, you need one bar(ex bar chart) with diff series…in this case just put the series & leave the categ values blank
kraf (BOB member since 2013-06-25)
