BusinessObjects Board
Dashboard with Tomcat Issue
We have upgraded BOXI 4.0 SP2 to SP5. After the upgradation we are getting the below error message while opening the Dashboard in BI Launchpad and in Dashboard Designer.
An Internal error occured while calling ‘ProcessDPCommandsEx’ API (Error:ERR_WIS_30270)
Error: Unable to load URL: https://:9443/dswsbobje/services/Session
Connection Type: Web service query (Query as a web service)
https://:9443/dswsbobje/services/Session - This URL is not working and we are getting the message as “Please enable REST support in WEB-INF/conf/axis2.xml and WEB-INF/web.xml”
Please let me know if you have a solution for this issue.
Warm Regards
Siva
SivakumarS :singapore: (BOB member since 2006-08-10)
We upgraded to SP5 and we are having the same problem.
Did you manage to get a solution?
BYOBjects (BOB member since 2013-03-04)
We also get this occasionally with SP5.5, but sometimes the dashboard loads fine, but much slower than in BOXI 3.1 where we have otherwise same dashboard and underlying webi report and BI web service except that the universe is done with IDT now. Any update on this?
Pekka :finland: (BOB member since 2012-02-24)
Did you generate the WSDL after upgrade?
kraf (BOB member since 2013-06-25)
WSDL has been regenerated many times after upgrade because we have added new “reports” in it.
But one thing related to this I noticed is that in our setup of two Windows server nodes (cold-warm), the other node’s WSDL is not in sync with the other one. How can we make sure they stay insync especially when the other one is down (SAP BI services, not the machine or Windows)?
to make it clear:
There is WSDL zip file which has all the WSDL…so when you upgrade this zip file needs to be generated.
use the below link to generate in all the systems.
use the correct hostname & port.
http://<hostname>: <port>/dswsbobje/qaawsservices/wsdlGenerator
hope it helps
Thanks kraf! I was able to sync the other node with this!
