I have multi-level drill down (four levels) dashboard. I use dynamic visibility to hide screens from where I drill down . An initial drill down works fine. I use a back button which clears the drill down value and thus hides the current screen.
Everything works fine the first time I drill down and backs out. The issue happens when I drill down a second time. For some reason the dashboard auto drills down after selecting from the first level, thus the user ends up at the lowest level.
I have the exact same issue. I just posted to another thread saying that if I save the report block (that is published as a Web Service) in the second level of the hierarchy, it lets me get to the third, and up to the first. This works, but ideally I’m not showing the second out of 3 levels on load of the dashboard.
Have you (or any reader) found a resolution or cause of this issue?
