Hello Folks !
I have a SAP BEx query with Mandatory variable with default value - Calendar Month. In Dashboard designer I have an optional prompt - Primary Sector.
Ultimately there should be a Query Prompt selector on dashboard screen where user selects Calendar Month and Primary sector is choosen from spreadsheet and a result from BEx should have both filters applied.Now I am not able to assign Query Prompt selector to Calendar month as it is grayed out. I assume this is called prompt dependency (because in my screenshot I see blue arrow against Primary sector)
How to get rid of that ?? Please help !!!
Screenshots attached.
Thanks in advance !
Aditional info:
(I tried applying SAP Note 1711564, assuming they described same as mine problem; but not did not help; still Calendar Month is grayed out).
Using - SAP BO Dashboard Designer SP4 Patch 5
[Edited, removed many blank lines. Thanks, Andreas.]
patricgates (BOB member since 2012-10-24)
