When I schedule a report to be refreshed & sent to users thru’ DAS, the moment the schedule starts, the DAS console hangs, thereby, not allowing login to other modules of BO also, returning a “cannot connect to security domain” error !
When I kill the DAS application which is hanging, then I can login to other modules. On DAS restart, the log for the report would have failed with error " Cannot complete Job Execution"
The error message appears because DAS was shut whilst a report was
running,
hence, it could not complete the job it was executing at that particular time.
In terms of the ‘cannot connect to the security domain’ - you may first want to check if you can successfully log in to the user module, and run a query from the same machine with the same user id which is running the report in DAS. This will eliminate if it is a problem with that
particular
user, and if your machine is functioning correctly.
Sometimes if you crash out of DAS it can corrupt the objects.lsi file in c:\program files\businessobjects\locdata. There should be a file called objects.bak in this directory which can be copied and renamed to objects.lsi (delete the existing one first).
Just a few things for you to check.
Hope this helps.
Melanie
********************************************************************** The information contained in this message is confidential and is intended for the addressee only. If you have received this message in error or there are any problems please notify the originator immediately.
The unauthorised use, disclosure, copying or alteration of this message is strictly forbidden. This mail and any attachments have been scanned for viruses prior to leaving Bank of Scotland Group network.
Bank of Scotland Group will not be liable for direct, special, indirect or consequential damages arising from alteration of the contents of this message by a third party or as a result of any virus being passed on. **********************************************************************
