Anyone noticed that once you create your initial query specification you
cannot edit it and have to re-create the whole datasource again ?
its cr*p.
Is there anyway around this terrible design ?
Al.
Botfield77 (BOB member since 2016-10-04)
its cr*p.
Al.
I’d agree with the summary in your second para, but having said that, I can edit my queries…
Click on query in the OUTLINE tab, then click on Data Source, Name in the PROPERTIES tab. Click on the little dots and you’ll see a pop-up. There should be a button to edit the query specification.
Debbie
Debbie (BOB member since 2005-03-01)
thanks !!
