BusinessObjects Board
Customize labels on X axis
I am using Stacked column chart and there on X-axis i am displaying months from JAN-NOV and last column is Budget. I want to display Budget something different.Presently all months and Budget are showing in same color.
How can i differentiate budget from months.:hb:
Can any one please help me.
Thanks&Regards,
Siva.
siva4bw (BOB member since 2013-11-15)
I would add another series for the Budget value.
For the new series, the values for JAN-NOV would all be 0, and you would have a value for the Budget series only.
Here’s a small example for JAN - AUG.
J F M A M J J A budget
1 1 1 1 1 1 1 1 0
2 2 2 2 2 2 2 2 0
0 0 0 0 0 0 0 0 5
Hope this helps.
-tkt
theknowtank (BOB member since 2011-04-20)
