Custom Sort Not Working?
Something I haven’t encountered before - custom sort doesnt seem to work:
Image (Chart) is attached showing my chart, what I am trying to sort by is the category axis. It looks like by default it’s sorting this value ascending.
Image (sort) is the custom sort I have assigned, but nothing seems to happen when I apply it?
I attempted to make a variable if statement to assign to the chart, which I planned to hide however it has to be a measure and I can’t assign a measure at the category axis:
=If([Banding]="-100% to -75%";1;
If([Banding]="-75% to -50%";2;
If([Banding]="-50% to -25%";3;
If([Banding]="-25% to 0%";4;
If([Banding]="0% to 25%";5;
If([Banding]="25% to 50%";6;
If([Banding]="50% to 75%";7;
If([Banding]="75% to 100%";8;
If([Banding]="No Stats";9
Image of this measure attached (banding sort).
Does anyone have any clever ideas here - i’ve not encountered this before with custom sorts…
Thomas
Thomas Evans :new_zealand: (BOB member since 2013-10-17)
Anyone able to shed some light on this?
If you want to custom sort why not do it on the bin labels/banding themselves?
That way you dont need the 1…9 at all.
Just a thought but is the numbering in the chart and then hidden?
IngeH :netherlands: (BOB member since 2004-06-22)
Hey, I am surely no expert, but if I wanted something to sort in aparticular way and NOT have to use the custom sort feature, I would add the sort number to the text of the bands.
“01: -100% to -75%”
“02: -75% to -50%”
Otherwise I would make a variable that said if Banding match “-100*” then 01, etc and sort by the banding sort field separately
I don’t see any images in your post, so if I am misinterpreting what you desired, I am not getting it.
Sorry-
Patti
pattinyc :us: (BOB member since 2008-09-09)
Personally, I would just sort the bandings as they are effectively a sort of hardcoding, in any case.
Sometimes you have to apply your custom sort the dimension using a temporary isolated tabular column to get it to apply.
When a custom sort is applied it affects all instances where the object / variable is used in the output.
You could also be facing Java issues, have you tried to apply it via the HTML panel?
pattinyc: thanks for that it seemed to work, but obviously the prefix isn’t ideal - because the chart at times wont have people in that certian band I get the effect of say: 01: band one 04: band 4 displayecd in my cat axis.
Mak1: I will give that a shot.
Thanks!!
Thomas
EDIT:
Hi Mak1:
I tried sorting the values in the dimension, didn’t seem to help at all, neither did the isolated sort.
My variables used to build this chart as as follows:
=If(([Agent Variance (%)] ForEach ([Agent Name])) Between(-100;-74.99); "01: -100% to -75%";
If(([Agent Variance (%)] ForEach ([Agent Name])) Between(-75;-49.99);"02: -75% to -50%";
If(([Agent Variance (%)] ForEach ([Agent Name])) Between(-50;-24.99);"03: -50% to -25%";
If(([Agent Variance (%)] ForEach ([Agent Name])) Between(-25;-0.01);"04: -25% to 0%";
If(([Agent Variance (%)] ForEach ([Agent Name])) Between(0;24.99);"05: 0% to 25%";
If(([Agent Variance (%)] ForEach ([Agent Name])) Between(50;74.99);"07: 50% to 75%";
If(([Agent Variance (%)] ForEach ([Agent Name]))>=75;"08: 75% to 100%"
=If([Banding] = "01: -100% to -%75";Count([Agent Name])*-1;
If([Banding] = "02: -75% to -50%";Count([Agent Name])*-1;
If([Banding] = "03: -50% to -25%";Count([Agent Name])*-1;
If([Banding] = "04: -25% to 0%";Count([Agent Name])*-1;
If([Banding] = "05: 0% to 25%"; Count([Agent Name]);
If([Banding] = "06: 25% to 50%"; Count([Agent Name]);
If([Banding] = "07: 50% to 75%"; Count([Agent Name]);
If([Banding] = "08: 75% to 100%"; Count([Agent Name]);
If([Banding] = "No Stats"; Count([Agent Name])*-1
Very strange :? .
Don’t know why you need to define the measure like this?
Wouldn’t this measure and your dimension buckets work in a chart?
If you look closely at some of those count(*) operations some are *-1 and some are not - I am trying to display those with a sub zero performance as a negative on the chart and those with a greater than zero as positive - per the second image I posted :slight_smile:
OK, got it :slight_smile: .
Just out of interest if you do define the measure in the way I suggested, does it change the sorting behaviour?
