I have an issue with custom sort and custom format in webi 4.1 SP 6 opendocument window.
I have a date column coming as MM/dd/yyyy i need to format it into MMM - yyyy when i right click on the respective date object and navigate into format number tab i could not see the custom option this is one issue. alternatively for this requirement i have written a formula instead of custom formatting my formula is:
=formatdate(date;“MMM yyyy”) this is working fine but the issue is when i drag this variable into a chart it is sorting alphabetically by default. when i want to custom sort it , the option is disabled the custom sort option is simply greyed out and not allowing me to select the values.
are these features not available in opendocument feature?
We are accessing BO reports via opendocument feature, we can modify and save them
Please help me how to achieve custom sort on date values
I’m using Rich Client (v4.1.6 P6, build 14.1.6.1933), and I can’t seem to make the custom sort work correctly.
The report was partially converted from Desktop Intelligence. The custom sort functionality worked fine in DeskI (v12.5.0.1190).
There is a section with a crosstab. I want to sort the sections in a custom order based on that section. However, I’ve removed all sorts. Then added an ascending sort for the section variable, and yet the option for custom sort is greyed out.
The particular report we were working with had been created many, mnay years ago. What we discovered was that happened in the Report Conversion tool process that “stuck” the first section at the top of the report.
Creating a brand-new report in WebI with the same data allowed the custom sort flexibilty we wanted.
