Custom filter by in Explorer
I have an information space that I need filtered based on a user name. I have created an information space with 2 columns 1 - User 2 - user number. I have followed the instructions from the tutorials to use this information space as my filter to my main information space.
When I to into Configuration for the main information space and select the Personalization tab, I follow the instructions selecting the User facet first and then when I select the facet from the To Filter, then click on the select the facet list from the filtered by selecting the correct facet. When I click on OK to save it will not save my change. It literally gets cleared out when I hit OK and nothing saves. Is there a SAVE button somewhere I need to click before OK.
SAP Question.doc (103.0 KB)
jfowler76 (BOB member since 2014-10-08)
