system
February 26, 2015, 2:44pm
1
if I concat currenttime() with another string I get ‘GMT+00:00’ added to the result
=CurrentTime()
gives … 15:45:67
="Hello world: " + CurrentTime()
gives … "Hello world: 15:46:67 GMT+00:00
How do I get just “Hello world: 15:46:67” other than using the replace() function. Is there someway to stop GMT+00:00 being appended if a ‘time’ type is coverted to a string?
Thanks guys
This is Webi BI4.1 SP5
JJ
jane123 (BOB member since 2006-02-22)
system
February 26, 2015, 3:15pm
2
Workaround:
="Hello World: "+FormatDate(CurrentDate();"HH:mm:ss")
hh=12 hour format, HH=24 hour format.
HTH
NMG
mcnelson (BOB member since 2008-10-09)
system
February 26, 2015, 4:48pm
3
thanks for the reply. Perhaps I was simplifying the issue. Its not CurrentTime but LastExecutionTime I’m interested in.
Just used CurrentTime as it doesn’t have any parameters.
Both return a ‘time’ data type. I’ll try your suggestion though.
JJ
system
February 27, 2015, 8:43am
4
You can apply the same to the lastexecutiondate() function to give you the time without regional information, e.g.:
="Hello World: "+FormatDate(LastExecutionDate();"HH:mm:ss")
HTH
NMG
