Current Month Function
Hello Everyone,
In our reports we created in report filters that automatically return current month data, a maintenance free filter. However there is a little problem to this approach.
For example here is our function:
=If FormatDate(CurrentDate();"yyyy-MM")=FormatDate([Create Date];"yyyy-MM") Then "Y" Else "N"
This function works great except for one day a month, where a new month starts, the first day. Our data is always at least the previous days data. So for example today is 5/1 so when you open the report it’s blank no data to retrieve for current month. I need help writing a function like that will always show current month data based on the last date availble in the universe.
So for example today is 5/1 but I need the report to recognize the last nearest date was 4/30 and hence still realizes it’s the last month.
We use SAP OLAP universes generated off of BW queries. So no universe manipulation.
Any help will be appreciated!
Rasesh :hb:
roshpatel :us: (BOB member since 2009-02-04)
Try this,
=If FormatDate(CurrentDate();"yyyy-MM")=FormatDate(([Create Date]-1);"yyyy-MM") Then "Y" Else "N"
KhoushikTTT :us: (BOB member since 2005-02-24)
Thanks I’m sorry I did not specify this.
The values we are using this for are not always in MM/DD/YYYY.
The equation that I’m using only gives us date in the format as MM/YYYY.
So how would the function need to be to address that format?
Thanks I have applied your other function to the universes that provide dates in the MM/DD/YYYY.
Rasesh
The report level solution would be a dirty huge formula with multiple nested If() statements. Go ahead with the universe solution.
