I used Running Sum to calculate cumulative sum of number of bills, but the used formula gives me incorrect sum.
Formula Used: =RunningSum([No of Bills];([Meter Size]))
The formula used is taking precedence on Number of bills (For Ex: The attached report has Number of bills as “1”, “2” and “4” based on consumption level. But, the formula is cummulating all the bills of “1” first and cummulating of “2” as second and “4” as third)
I have to show cumulative no of bills based on consumption level (Attached file has mock-up calculation which i manually added for better understanding).
The report has secitons on Rate Code, Customer Type and Meter size.
is that object you’re trying to sum a dimension or a measure? because looking at that data something doesn’t automatically make sense to me. one or more of those columns with numbers inside must be a dimension and not a measure. maybe that’s what the problem is.
