.csv File Generation Using WebI
I have a requirement. Kindly suggest the possibilities of achieving that.
Current Scenario:
  1. PL/SQL code generates a pipe separated text file.
  2. This extract has a pre-defined header and footer.
  3. This extrcat is sent to Users, at scheduled times, through Unix Cronjob
Proposed New Scenario:
  1. The user should be able to generate a .CSV file, himself, whenever he wants it.
  2. The user expects this solution in WebI
May I know the possibilities of achieving this requirement, especially the header and footer.
Sample Data:
Header Part-1| 12345|123456987.12457
something|something|something|
Footer116444gfs
digitalgopi (BOB member since 2006-05-31)
