csEX Error WebI 4.1 SP8
I get the csEX Error in reports and the error is very random and intermittent. Doesn’t occur in just one report /universe but across multiple reports/universe.
This happens only in the Pre Prod Environment and LIVE runs perfectly ok.
Have tried searching the forum(not much info) and also raised Incident with SAP, anyone else got this and found a solution?
su.bi (BOB member since 2010-12-06)
It rings a vague bell. I have worked on 4.1 SP8. Is that the entire error? If you have access to the CMC/Servers look for a Web Intelligence Processing Server restarting at the time you see the error.
I believe that means the Connections Server is stopped or disabled.
We tried restarting both servers. SAP have been very quick in responding and they are in touch with the Admin team! Will keep you posted.
Thanks Much
Please find the below resolution steps taken by the SAP Team to resolve this issue.This fixed the issue for us.
Incident Number: We are getting csEX error while trying a report in the pre-production environment.
========Problem Description==========
Error “csEX” is displayed while refreshing WEBI reports
=====Environment=====
4.1 SP8
UNX
Standalone
======Call Summary============
-When refreshing Webi report through BI Launchpad it gives error: “csEX”
-The manually created APS servers where not responding and we were still facing the error.
-The issue was observe with the APS with split services as well as default server as it was not split properly.
-To resolve the issue we tried to split the APS using “System Configuration Wizard” according to KBA:
2030389 - In WebI, what is a “csEX” error? How do you resolve a “csEX” error?
-You have done port biniding for these server and currently the reports are working fine. You will monitor the issue for 2 to 3 days more.
Thanks for letting us know…I don’t suppose you know which APSs were misconfigured?
Sorry No! This is what our IT support team sent for the resolution.
