crystal xi
I am new to crystal reports, can i know how can we integrate crystal reports to sap…
and also I am having one more doubt,…
How can we show integrate crystal report data into crystal xcelsius and create dash board.
plz help me …
i want step by step…
thanks,
Mahesh
mahe416 (BOB member since 2010-04-01)
Please supply the versions of software that you are using.
JBray :us: (BOB member since 2008-07-15)
I am using the versions of crystal reports 2008…
and xcelsius 2008
You can get an SAP Integration Kit or use ODBC, etc.
You can export the data from Crystal to XML format which feeds into the Xcelsius.
You can export the data to Excel format and manually import the data into Xcelsius.
You can embed the Xcelsius into your Crystal report.
I hope this helps.
You can also connect directly from Xcelsius to SAP Bex queries, pre-requisite: SAP BW 7 EHP1 SP5+ and Xcelsius 2008 SP2+
Its very helpful to me…
I am having a doubt…
whether we can loops in crystal reports while linking tables…
if so how can solve it…
and Also i am facing a problem while creating the prompts in crystal reprts.
I have taken the database connection as business object universe.
Report creation evrything is ok in crystal reports but when i am creating a promp im not eble to see the list of values in the value field.
Can any one solve this …
it will b help ful for me…
with regards,
Mahesh
