Crystal XI - Conditionally showing/hiding Text boxes ...
Greetings Fellow Bobjs,
I’ve recently started working with Crystal again after an absence of a few years of not using product and I’m struggling with getting Crystal to conditionally hide/show Text boxes. I can’t recall if I was able to do it previously in Crystal because the last time I used Crystal it was using Crystal with VB at the time and I’m originally a VB man, so I would have probably tried to do everything programmatically using VB (I’m guessing) and this time around I’m only using Crystal not Crystal and VB
What I am trying to achieve at the end of the day is …
… “if a value for a database field shown on the report happens to be NULL for whatever reason, I do not want to show this Text box or the associated Label for the Text box. But if is it NOT NULL then I want to show the Text box and the associated label for that Text box on the report.”
My preference is not to create a new section header, ie and show/hide that (if that works). However, if there is no alternative then I guess I will look at that. I’m not sure if that would work? Anyone??
Thanks in advance!!
Bobbafett
bobbafett (BOB member since 2007-10-18)
Did you look at the format expert and try the formula editor to make the text box dissappear or become invisible?
Hope that helps.
khajasamiuddin (BOB member since 2006-06-23)
Thanks for the reply.
Yes, I tried to use Formula editor yesterday, but I had difficulty figuring out what the properties that I could interrogate were.
I was hoping to do something like …
.visible=true
Is there a particular property that I can access programmatically via Formula Editor to make a Textbox visible/invisible?
Thanks in advance!
Good day my mandalorian armoured friend.
Right click > Format Text, then youll see a tick box labelled suppress. On its far right there is a formula button, into which you can put a condition that returns a boolean. True = Suppressed, False = Not Suppressed.
