Hi - Does any one have any experience with Crystal Reports? I’d like some information about how to position BO with Crystal Reports at my organization. Thank you!
Thank you!
The way we have it positioned as:
For Crystal Reports
Everything else we use WebIntelligence (1st) and Business Objects (2nd) for doing reporting.
Hope this helps…
Lisa Hale Lisa.Hale@STEELCASE.COM 12/30 12:29 PM >>>
Thank you!
Sincerely,
Thomas Nather
Penske Logistics
email: Tom.Nather@Penske.com
Ph: 216-765-5787
Fax: 216-765-5666
Hi Lisa,
I have experience with both Crystal and Bus Obj. There are two very different
reasons to use each tool. For example, Crystal is great for generating standard
reports. There is little or no opportunity to manipulate these as they are mostly
for month end or week end reporting.
Bus Obj is great for putting the ultimate power in the hands of the end user.
While Bus Obj can be used for week or month reporting, using Doc Agent is weaker
then crystal Info’s scheduler. I know that the version 5 release of Bus Obj
promises to greatly improve the “Doc Agent”
If there is any information that I can give you in addition to this (I know a
great deal about both tools) please email me at laurenf@bellatlantic.net and I
will gladly give you more info.
Thank you!
Hi all,
Is there any way to easily (without recreating) convert Crystal Reports into BO Reports?
Cheers
Martin
********************************************************************** This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail: to do so could be a breach of confidence. Please notify us immediately by reply e-mail and then delete this e-mail from your system. Please contact our IT Helpdesk on +44 (0)20 7212 0888 or e-mail ukithelpdesk@corp.vizzavi.net if you need assistance.
E-mail transmission cannot be guaranteed to be secure or error-free as information could be intercepted, corrupted, lost, destroyed, arrive late or incomplete or contain viruses. The sender therefore does not accept liability for any errors or omissions in the contents of this message that arise as a result of e-mail transmission. If verification is required please request a hard-copy version. This message is provided for informational purposes and should not be construed as a solicitation or offer to buy or sell any securities or related financial instruments.
This e-mail has been sent through the e-mail gateway of Vizzavi Europe Limited (“VEL”) on its own account or on behalf of and for the benefit of other Vizzavi group companies who use this facility from time to time.
VEL Registered office - 80 Strand London WC2R ORJ England. Registered in England No. 04064873
For this message in Dutch, French, German, Greek, Italian, Portuguese and Spanish, click on http://www.corp.vizzavi.net/disclaimer/
Visit Vizzavi at: http://www.vizzavi.net/
This footnote also confirms that this email message has been swept by MIMEsweeper for the presence of computer viruses.
Could you just pull the SQL from Crystal, and create free-hand sql reports? Even if this only works for some of the simpler reports its going to reduce 800
to a (more) manageable figure.
cheers, Nick
********************************************************************** The contents of this e-mail and its attachments are confidential and may be subject to legal privilege. The contents may not be disclosed, copied or distributed without our consent. It is intended for the use of the addressee(s) only. If you are not the intended recipient you must delete this message immediately and advise the sender that you received it in error. The statements and opinions expressed in this message are those of the author and do not necessarily reflect those of the Company. The Company does not accept any responsibility for the author’s views.
Whilst the Company takes every effort to ensure this message is virus free it can not guarantee that this is the case. It is the recipients responsibility to carry out such virus checks as it deems necessary. The Company can not accept any responsibility in this regard.
Please note that this e-mail has been created in the knowledge that Internet e-mail is not a 100% secure communications medium. We advise that you understand and observe this lack of security when e-mailing us.
Hi Marty,
I have the same problem here: converting about 800 reports from Crystal into BusinessObjects…
Delphi Software GmbH, Vivenotgasse 48, A-1120 Wien, Austria http://www.delphi.at
I will also be going through this in the next few weeks - so any advice would be hugely appreciated!
If you are just going to use the same SQL, I don’t see a reason for conversion. The best way out is to design your universe based on the existing reports. I don’t see any easy way out. We are in the process of converting
SQR Procedure reports to BO. We have divided our report onto 3 diff categories and are
designing 3 types of universes(with diff connection parameters) .We have 3 diff reports category which uses diff data sources(diff databases sitting on diff
servers,but almost identical tables). We are in the process of designing a single report and then
going to use VBA Macro to change the universe on which report can be run.
Think in this line.
-Durgesh
No chance, there is alot of grouping and local computation done in the reports, the structure should somehow be preserved. What I can imagine is to use the “textual” representation (don’t know the exact name for this) an to create BO reports by VB scripts…
So, if anybody out there has already done something similar, let me share your knowledge.
Walter
Looks like now is a good time to evaluate which reports you really need, then hire a consultant to help you rewrite what’s left ![]()
w.muellner@DELPHI.AT 11/06/01 08:58AM >>>
Walter
I AM the Consultant ;-)))
and me please
Well, when I had to convert our 183 Crystal reports I found that when I was done (2 weeks later) that I only had 64 BO reports because I was able to consolidate based on similar data providers. I don’t see how else you can get around this issue unfortuneately
Martin.Lidl@CORP.VIZZAVI.NET 11/06/01 10:46AM >>>
and me please
