Crystal reports XI ODBC error - Sun machine
Can anybody provide a a solution, how to deploy the crystal reports connecting to SQL server using INFOVIEW portal.
The server is Sun Solaris, tried all possible ways, got exhausted.
The odbc.ini is located on /export1/home/boxir2/bobje on Sun machine.
Here is the odbc.ini entry for which I’m connecting to “test_sys_ss”
[ODBC Data Sources]
CRSQLServerWP=DataDirect 5.1 SQLServer Wire Protocol Driver
test_sys_ss=DataDirect 5.1 SQLServer Wire Protocol Driver
CRSybaseWP=DataDirect 5.1 Sybase Wire Protocol Driver
CRText=DataDirect 5.1 Text Driver
crystal_report_dcai1=Oracle in OraClient9i02 driver
crystal_report_ora=Oracle in OraClient9i02 driver
[test_sys_ss]
Driver=/export1/home/boxir2/bobje/enterprise115/solaris_sparc/odbc/lib/CRmsss21.so
Description=DataDirect 5.1 SQLServer Wire Protocol Driver
Database=DiskMonitor
Address=168.109.241.233,2431
QuotedId=No
AnsiNPW=Yes
LogonID=diskmon
Password=password
Any connection or anything that is missing, please let me know.
la_cool :us: (BOB member since 2007-01-10)
My dear friend,
You should not try connecting with ODBC connection. For SQL Server you have to create OLEDB connection and save it .
Now … see…
Madhu@Cargill
remata :us: (BOB member since 2006-04-19)
Thanks remata! It is working now.
Your most welcome!
Hi Remata
I am trying to create Crystal Reports to use on Infoview
But I dont know whether to use an ODBC or OLEDB connection to SQL Server
Can you let me know why OLEDB is preferable to ODBC for accessign SQL Server through Crystal Reports
Ruchira
ruchiraw :australia: (BOB member since 2005-12-27)
Yes. You have to use OLEDB connection for SQL Server database. You can
t use other connections.
Remata.
Thanks a lot Remata
Woudl you happen to know whether we have to use OLEDB for connecting to Oracle as well . I am planning to create reports which use both Oracle and SQL Server
Ruchira
ODBC works fine for oracle. No need OLEDB.
Oracle has inbuilt futures for BO product.
Thanks a lot Remata
srinivas_ch (BOB member since 2007-07-15)
