I have a Crystal report that has a command object (SQL). When I run the SQL in the command object in SQL Server it returns more entries than when I run the same code in Crystal 16.
I tried to select just 1 certain entry in Crystal, it does not pull anything. SQL does pull that 1 record.
I am lost as to why? I would appreciate any help on this.
marilynginger (BOB member since 2019-02-27)
(BOB member since 2010-06-23)
