I have a report I was asked to create. I am new at creating reports.
The report will include the Call Type field from out ticketing software. I included this field in the report and a count of each call type. In the select expert, I am able to select RecvdDate and choose whatever timeframe is needed.
I was also asked to include a chart on the bottom of the report to show totals of call types for the past 12 months. I have been researching for a few days now and can’t seem to find an answer. From what I have been reading, I would need to use a formula, but all of the suggested formulas give me an error.
Any help would be appreciated. If more info is needed, please let me know.
send the example of formula which is giving error for easy debug… what is the error message coming… based on that you can easily solve the problem. most of the cases it is a casting problem character to number and number to character…
Are you putting the formula in the selection criteria area? But I am confused by what you are trying to accomplish in the formula. This is what I am reading for the first line. Get the date from a year ago today and subtract the day of that month a year ago then add one (day). If you are trying to get the first of the month a year ago, there are other formulas that are easier to read (I would need to do a search to find them).
I was able to get the correct totals in the report itself. It turns out that I had one of the groups duplicated in the report which was giving me the wrong totals.
The only issue I have is with the chart. I was able to add the chart. But I’m not sure how to have the chart display the past 12 months of totals.
You would definitely get an error if you put those lines in the group selection since it is looking for a true/false result to filter records.
So are you filtering the data now for the last 12 months? If not, you may need a sub-report and put the chart there (using similar formulas as above). I would think you would use the first line for your start date and use the current date for your end date.
