Hello Members,
I have to develop a report and show the data that is stored in xml in a column in the physical table.It comes down to creating a dataset out of a query. In Crystal reports, i have developed a report using xml file as dataset and it works great. How can i develop a report if that information is stored in a column in physical table. Any inputs are greatly appreciated.
Sowmya-
Thanks for taking your time to look into this. Pulling the data is not a problem. I have to display the data and format based on th xml code. The data is stored in xml format in the column. I have tired html text interpretation but that did not work.
For example this is a sample xml code:
<?xml version="1.0" standalone="yes" ?>
1
Product1
10
2
Product2
15
3
Product3
350
4
Product4
75
5
Product5
100
6
Product6
600
This how the data is stored in the column. Out of this you have to read the data.
