system
May 28, 2019, 10:20pm
1
Thanks for the add folks.
I am running a crystal report from a web based application however it asks me for the SQL SA username and password.
When i enter them the report works fine. The report will be used by a number of users so passing on the password is not an option.
How can i go about this?
Cmey (BOB member since 2019-05-28)
system
May 28, 2019, 10:24pm
2
Since we do not know the web based application and how to set up a default user name and password for running reports on the application, it would be difficult to say.
kevlray (BOB member since 2010-06-23)
Sounds like someone set the SA user as the default text in the login text boxes. Can`t you just overtype with a different SQL Server user?
ABILtd (BOB member since 2006-02-08)
