Crystal in Advanced function presentation
Hi BOB Users
Please advise me if Crystal can be generated in Advanced function presentation(afp) format. If yes then what could be the possible steps.
Any help would be appreciated
regards
Sumit Agrawal
sumit_agr (BOB member since 2008-03-05)
No, it can’t. The only export options you have are the ones you seen in the Crystal export dialog - standard stuff like PDF, Excel, Word, Text, etc.
-Dell
Thanks Dell for your help…
I am not sure …but is there a posibility using Crystal SDK… Please suggest
regards
Sumit Agrawal
The SDK only exports to the formats that it knows about - it’s a wrapper around existing functionality in Crystal. I don’t know if there is information available from SAP for building your own export .dll, but you would have to be able to “read” the report and then convert it to the format that you need. It’s pretty low-level functionality which is not really available in the SDK.
-Dell
