system
February 22, 2010, 9:52am
1
While opening Crystal Reports 2008 I am getting this error.
The procedure entry point ?PrintLegend@CMapXLegend@CSLib300@@QAEXJJJJ @Z could not be located in the dynamic link library cslibu-3-0.dll
Any help would be appreciated…
Raghvendra Deshpande (BOB member since 2008-05-26)
system
February 22, 2010, 1:19pm
2
Can you try on some other machine and see if same issue occurs there.
Cheers!!!
Manish
cr_manish (BOB member since 2009-07-30)
system
February 27, 2010, 11:51am
3
This problem was resolved when I installed SP 2008 sp1.
We get this same error from Crystal Reports 2008 sp2 after installing the service pack 2.6 for BO XI 3.1. Anyone else run into this?
JB_BOlead (BOB member since 2008-04-17)
We are also getting the same error after installing SP2 for BO.
Did you guys resolve the issue? if so can you please tell me the procedure.
ay1224 (BOB member since 2007-07-30)
SAP suggests to
Download and install Service Pack 1 for Crystal Reports 2008.
I mean the BO and the crystal versions has to match. so we have to apply the patches accordingly.
system
May 14, 2010, 10:00pm
8
We solved it with Crystal Reports fixpack 2.7, and also installed BO fixpack 2.7.
BO SP 2.6 Crystal combination definitely needs both, and BO SP 2.6 needs fp 2.7 even if it does not have a Crystal intall.
Our Crystal 2008 install was already on sp2, and a clean install with SP1 did not work with BO sp 2.6 either.
