How do i make an aggregation on a column if there are zeros and ones in the column?
I would like the aggregation only on the “1”
Normally i would do the aggregation on a ID field but not all fields are filled so the result wouldnt be correct.
Note; i only make this aggregation so i can use this in a crosstable, i also have another aggregation in this crosstable so i cant filter on the column with the ones and zeros…
tantetruus (BOB member since 2008-11-11)
