Cindy wrote:
Does anyone know if it is possible to have independent columns on BOTH
sides
of a crosstab block?
sides
Cindy, I have done this by inserting a calculation (calculator button) into
my crosstab. I then delete the row level total (ie: horizontal line)
generated by the insert calculation. I then copy the column on the right of
the crosstab (which I also want to appear to the left of the crosstab).
Then, using Edit…Paste Special, I paste both the content & format into the
column level total (ie: vertical line)generated by the insert calculation.
