CRMXIF_PARTNER_SAVE_M02 BDoc
I’m working on CRMXIF_PARTNER_SAVE_M02 BDoc and getting the following errors Error status 'A ’ calling validation service
, Validation error occurred: Module CRM_BUPA_MAIN_VAL , BDoc type BUPA_MAIN,Error_Time Dependency_Addresses ADVW_VALIDITY_ERROR
, Error for validity periods of address usages, ‘Object method for object 1 set from to I’ in the CRM system. If someone has come accross with this issue and resolved, can you please help me on this. And I’m using DS 4.0 sp2. Thanks in advance.
rk.us (BOB member since 2012-08-23)
Can you call the very same function with the same parameters via SAPGUI?
Are you using bdocs via bods? If so, why on earth are you using replication messages for sending data to crm?
