Hello, i’m trying to code a treeview in VB which must be exactly the same than Reporter’s explorer. but i have a problem to access the good variables and formulas.
For example : this is Reporter Treeview :
and this is how my program looks like :
as you can see, i can recreate the variables “Variables” by using this this code :
Dim nodX As Node
TreeView1.Nodes.Add(, , "r", "Racine") = "Variables"
Dim nbvariables As Integer
nbvariables = RapportBO.DocumentVariables.Count
For i = 1 To nbvariables
If RapportBO.DocumentVariables.Item(i).Qualification = boDimension Or boDimension And RapportBO.DocumentVariables.Item(i).Name <> "" Then
TreeView1.Nodes.Add("r", tvwChild) = (RapportBO.DocumentVariables.Item(i).Name)
End If
but I can’t recreate exactly the formulas “Formules” as in reporter because i don’t know how to distinguish hidden formulas, unused formulas, etc…
For example, in reporter in the node “Formules”, I only have “=Nombre()”, but in my VB treeview, i also have 11 more formulas ("=Page0" for example), but i don’t want these ones.
Any idea ?
bleepsarace (BOB member since 2004-07-30)
(BOB member since 2002-09-19)
