Creating reports from CMS Repository XIR2
Has anybody who tried access BO CMS Repository XIR2 and provide reports from it?
We are not going to use Data Integrator.
Thanks in advance for any responses.
Mike
usmwi :us: (BOB member since 2007-02-28)
Create reports from CMS repository is nothing but designing reports from a auditing universe
rollings007 :poland: (BOB member since 2007-02-15)
We have an Downloadable available in the forum to get the BOXI User List and Groups.It may help you…
Siva.M
looksmee :uk: (BOB member since 2006-02-08)
Thank you for the responses.
Also, is there a way to report Universe relationships with all report objects? Example, if a Universe needs to be changed produce a list of all report objects that would be effected.
Mike
Download Security Viewer from Bo website
Try on BOB Downlaods…There is an Link which helps to Document your Report with List of Object used.But i dont think you can automate the process to identify the list of reports effected due to the changes on the Universe. Needs to do it manualy…
Siva.M
This thread may be of help to you:
crystal01 :us: (BOB member since 2006-08-30)
