Hi, i am new on bo sdk. i am using some little vba, and now i want to create a user from excel. they will be in a group that insert from excel. is it possible?
hasmir99 (BOB member since 2013-05-23)
If you are not yet on BI4, you can use the Import Wizard to create the users. You can’t do it directly from Excel, but you can save the Excel file in CSV format to be imported.
Joe
joepeters (BOB member since 2002-08-29)
i am using bo xi3.1, and i found something.
i ll try this. if i can write then i ll send forum.
http://scn.sap.com/docs/DOC-6405
hi again, i wrote a program. it s only create a user.
you must add to reference these component.
CrystalDecisions.Enterprise
CrystalDecisions.Enterprise.Desktop.User
CrystalDecisions.Enterprise.Framework
CrystalDecisions.Enterprise.InfoStore
CrystalDecisions.Enterprise.PluginManager
http://yadi.sk/d/vk87SOiq6dU_x
