Hello expert,
I want to create a crystal report with two different data set, how can I put those two different data set separately into two tables?
Many Thanks,
cetzhbo (BOB member since 2011-03-30)
Hello expert,
Many Thanks,
Need a bit of clarification. Are the two data sets related to each other (i.e. have a joining field)? Then you should be able to use a command or the database expert.
If not, then it probably would be best to have one data source in the main report and another data source in a sub report to avoid a Cartesian product issue.
I hope this helps.
kevlray (BOB member since 2010-06-23)
thanks, but my data source for subreport is the procedure same as main report, how can I merge those duplicated parameter together? those parameters are set in the oracle store procedure.
I have not used Oracle stored procedures. So, my suggestion may not work with them.
I am not sure what you mean by duplicated parameter?!?
my main report and subreport are using the same procedure, this precedure has 3 parameters, so when I run the report, there are same 3 same parameters showed up individually for main report and subreport, in WEBI report, we can merge those parameters with same description, but how can I implement it in crystal report?
Again I am a bit confused. You say the parameter show up on the main report and the sub-report. So you are displaying the parameters in the main and the sub-report? If not, then I need to understand what you mean by ‘there are same 3 same parameters showed up individually for main report and subreport’.
in the parameter dialogue, parameter presented in following sequence:
par1
par2
par3
par1
par2
par3
upper part for above sequence is coming from main report, and lower part is comming from sub-report.
I only need it to present as follows:
par1
par2
par3
see, there three parameters can be use in main and sub report. I only need to input once for each parameter
