create object with UserResponse
i my webi report i create the following object:
=UserResponse(“Enter Period:”)
This object i use in one of my column so it will show for all rows same period.
But i need to use Qaaws, but because you can not create objects within qaaws, i need to create this object within universe.
How can i do that?
Hopefully someone can help me
Swimmer :netherlands: (BOB member since 2006-08-23)
Use @prompt() function.
You mean create an object:
period format = yyyymm
@Prompt(‘Enter Period:’, ‘A’, mono, constrained)
Add place that object in the report?
Yes.
im doing something wrong
object name Start
in select:
@Prompt(‘Enter Period’,‘A’,‘Sales\Period’,mono,constrained)
when parsing i already got an error:
Syntax error, expected something like name or a Unicode delimiter identifier or ‘(’ between the From keyword and ;.
But i still exported universe to repository and i used this object in report(not as filter) but in the results objects
But when running report im getting the famous Api error
my issue is more complex then i thought
Currently i have the following prompt in my webi report
Period BETWEEN Start and END
Start is a prompt name
End also
In my webi report i am using
=UserResponse(“Start”) and in other column I am using
=UserResponse(“End”)
My values are 201005 and 201107, so im getting two column with only 201005 and 201107 and the rest of the report is showing data being calculated for this period
So in my webi report its working
Now i need to do the same in Qaaws
so i created two objects in my universe
Object name: Start
Select: SALES.Period
Where: SALES.Period>=@Prompt(‘Start’,‘A’,Mono,Free,Persistent)
Object name: End
Where: SALES.Period<=@Prompt(‘End’,‘A’,Mono,Free,Persistent)
Now i add both objects within my report, and if i run the report, im getting my two prompts where i can fill in 201005 and 201107, but in my report im getting values for Start from 20105 -201107 and for end the same. So its not taking my inpyut for the prompts.
Hopefully you understand what is going on, and can you help me.
the problem is the between and that i need both values in seperate column
It’s simple, I guess.
Object name: Start
Object name: End
Replace <= and >= by =
no that won’t work either because then i have the following SQL code:
SELECT
( SALES.PERIOD ),
( SALES.PERIOD ),
SALES.REGION,
SALES.EMPLOYEE_NAME,
sum(SALES.NET_SALES)
FROM
SALES
WHERE
( ( SALES.PERIOD )=@Prompt(‘Start’,‘A’,Mono,Free,Persistent) )
AND ( ( SALES.PERIOD )=@Prompt(‘End’,‘A’,Mono,Free,Persistent) )
GROUP BY
1,
2,
3,
4
And because you are getting a "AND"in your prompt you won’t get any data.
Can you replace the where in your definition by a case statement?
what do you mean?
What is in the where clause is coming from the both objects right.
I didn’t get what you meant. However this FAQ can give tips.
this is the created SQL code by business objects:
Posted: 27 Jul 2011 16:14 Post subject: Re: create object with UserResponse
SELECT
( SALES.PERIOD ),
( SALES.PERIOD ),
SALES.REGION,
FROM
SALES
WHERE
GROUP BY
1,
2,
3,
4
As you can see in the where clause i am getting "AND"instead of BETWEEN, that is ofcourse becasue im having two objects seperately within universe.
So my issue is that is want to have a between, and show the input values of both objects within my report (QAAWS)
Swimmer,
I think your query should look something like:
SELECT
SALES.PERIOD,
@Prompt('Start','A',,Mono,Free,Persistent),
@Prompt('End','A',,Mono,Free,Persistent),
SALES.REGION,
FROM SALES
WHERE SALES.PERIOD between @Prompt('Start','A',,Mono,Free,Persistent) AND @Prompt('End','A',,Mono,Free,Persistent)
GROUP BY
1,
2,
3,
4,
5
Create 2 objects and drag them in your Qaaws:
Object_start: @Prompt('Start','A',,Mono,Free,Persistent)
Object_end: @Prompt('End','A',,Mono,Free,Persistent)
Hope this helps,
Johan
JdVries :netherlands: (BOB member since 2006-02-06)
It’s working perfectly thanks!!
Swimmer,
You’re welcome :mrgreen:
Johan
