Create dtd´s or xsd for Import and Export
Hello together,
I have to create dtd´s or xsd schemas to import data from the designer to SAP R3 and Export Data from SAP R3. How can I create those files?
We work together with functions to get the data to SAP and back to the 3rd party software. Thank you for any help.
Regards Dieter
dibafr (BOB member since 2012-08-17)
Dieter, when you import a function from SAP you do not need dtd’s or xsd’s.
When you call a SAP function inside a dataflow you can directly map/nest the data in a query and then on the SAP function.
Thank you Johannes. It works now. Regards Dieter
Good to hear :+1:
