Dear ALL,
I’m using Opendocument in order to open a Crystal report. The repor has a multiple prompt where I can set NULL in the prompts parameter.
How I can specify null values on Opendocument string ?
This string doesn’t works fine :
http://SERVER_NAME:8080/BOE/OpenDocument/opendoc/openDocument.jsp?sIDType=CUID&iDocID=AbpSeIvDGNpHnMKvC7YaJp4&promptex-[ZSD_DEMPL_MF_CID]=NULL
Also this string doesn't works fine :
http://SERVER_NAME:8080/BOE/OpenDocument/opendoc/openDocument.jsp?sIDType=CUID&iDocID=AbpSeIvDGNpHnMKvC7YaJp4&promptex-[ZSD_DEMPL_MF_CID]=ALL
Also this one doesn't work(as specifed on this PDF http://trustedbi.com/files/xi3-1_url_reporting_opendocument_en.pdf - Pag. 30) :
The Crystal report is based on BEX query and the prompts are applied on the BEX Query and not onto Crystal report
Any Idea?
Best Regards,
ZAV
zavatta_fighter (BOB member since 2005-05-10)
