Migrating a report from CR-9 to CR-2008 which uses the “Oracle Native” driver (Oracle 9i).
There are a large number of LINKED tables with LEFT-OUTER JOINS in the Query which runs fine in CR-9.
In CR-9, the SQL is executed with the LEFT-OUTER JOINS in the WHERE statement -
eg. WHERE “TABLE_A”.“PROJECT_NUMBER”="TABLE_B.“PROJECT_NUMBER” (+))…etc
In CR-2008, the SQL is executed with the LEFT-OUTER JOINS in the FROM statement -
eg. FROM (“ABC”.“TABLE_A” “TABLE_A” LEFT OUTER JOIN “ABC”.“TABLE_B” “TABLE_B” ON “TABLE_A”.“PROJECT_NUMBER”=“TABLE_B”.“PROJECT_NUMBER”)…etc
Because of the large number of LINKED tables with LEFT-OUTER JOINS in the Query, the FROM statement from CR-2008 is being cropped/truncated by the Oracle 9i driver, and the SQL request is FAILING.
Anyone know of a good way to fix this issue either on the RPT-side in CR-2008, or by changing the SQL LENGTH rule in Oracle…?
Thanks in advance for the help!
MJRBIM (BOB member since 2007-03-23)
