CR 2011 - Complicated joining of 3 DB fields
Hi all,
I need some help with CR 2011 formula
Please check the image attached
Thank you.
neo86 (BOB member since 2012-09-06)
In CR2008 the following syntax concatinates the fields together
{Table.Field_1}+ {Table.Field_2}+ {Table.Field_3}+ {Table.Field_4}
I am going with the asssumption that 2011 is not significantly different.
amosgreg (BOB member since 2012-01-27)
