Hello everybody,
I am using Crystal reports 2008 and BW Query as Datasource.
After I have selected the Set Datasource Location menu and updated the selected table I’m taken to the Map Fields dialog box. Under the Unmapped Fields on the left side I see the current fields in my report. The issue is, there are no fields on the right side to map too. What should I do to see the fields on the right side to map, they are existing in the new query.
Thanks for any help!
Hugo (BOB member since 2010-04-14)
