Good morning,
I am trying to count the weeks in a month in my Bus. Obj. report. Does anyone have any suggestions on how that can be achieved?
Daintysally
daintysally (BOB member since 2005-12-20)
Good morning,
Daintysally
The recommended approach is to use a smart date calendar table in the database / universe. There are so many different ways to define week (start on Sunday or Monday … what if Monday is a holiday … and so forth). In the calendar table, populate a column with “week number” based on your company’s definition. Then it’s a simple matter to count the number of unique week numbers within month.
Dwayne Hoffpauir (BOB member since 2002-09-19)
Thank you for your input. I have never used/created a smart date calendar table. Can you give further input on how to do this?
Thanks Again.
As Dwayne suggested having it done in the universe is an excellent solution, if that’s available to you. If not, can you define what a “week” is and how you want it counted? In other words, is a week simply 7 days? Or is it a period of 7 days from Sun - Sat? Do you want only full weeks (those where the complete Sun - Sat is contained within the month)? Or are partial weeks okay?
There might be a formula that can be done in the report, but the process needs to be defined first.
Thank you both for the excellent guidance.
A week is being defined simply as seven days. I do have the universe available to me, but I would prefer that it be done at the report level.
You know the current date with the CurrentDate() function. You can get the number of days in the month with a combination of LastDayOfMonth() and DayNumberOfMonth. So this will give you the number of “seven day periods” in a month:
=Floor(DayNumberOfMonth(LastDayOfMonth(CurrentDate())) / 7)
Find the number of days in a month, divide by 7, throw away the remainder. That will give you the number of “complete” 7 day periods in a month. If you want fractions, don’t use the Floor() command.
Does that get you what you want?
Because of my lack of knowledge of the data, I apologize for saying that a week was as simple as 7 days. By report is set up by month based off of the fiscalweek.
This is the breakout out of weeks according to our fiscal calendar starting with August:
Aug: 8/1 - 8/28 (4 wks)
Sep: 8/29 - 10/2 (5 wks)
Oct: 10/3 - 10/30 (4 wks)
Nov: 10/31 - 11/27 (4 wks)
Dec: 11/28 - 12/31 (5 wks)
In my report, I am wanting to show a count of the fiscal weeks in a month. :?
If you have a fiscal calendar, I assume you have a fiscal calendar table then. That would be your best bet using the strategy suggested earlier.
