But it is impossible to apply Count() to a measure, neither to set a break
on it.
Define a new object in your universe, a user object or a variable, give it
a suggestive name like Analysis_result_asDimension and set it to the value
of Analysis_result. After defining it in the “formula tab”, go to the
“definition tab” and set it to “dimension”. Use this object/variable
instead.
Rui Miguel Amaral de Sousa Pedro
Siemens S.A.
tel: +351 (01) 424 2111
fax: +351 (01) 424 2054
