I am using Edge 3.1 and been facing the DX0005 and RFC00101 errors which according to the BO site is a software bug which is being take care of in Q3 2010.
Look at the last post in this
However, i found a temp solution (not the best) to this problem. If i were to create a batch file to constantly delete the folders created within the cache folder then this issue does not arise. Since the sub folders within the Cache folder are randomly generated, please could someone help me with a batch file or a command i can use via the Scheduled Task to be fired to delete the files (whose name i cannot control) from the cache folder.
BOB_US (BOB member since 2006-03-16)
