We have working sdk-application in boxi3.1 and now we want to upgrade it to work with boxi4.1.
We have updated the jar-files, but still it gives an error:
org.springframework.web.util.NestedServletException: Handler processing failed; nested exception is java.lang.NoClassDefFoundError: Could not initialize class com.businessobjects.bcm.BCM
We have this necessary bcm.jar in our war-package, but still it doesn’t initialize the BCM class.
I have tried to put the jar-file also in tomcat/lib, but it doesn’t help. We have tomcat 6!
Make sure you have the correct dependencies at run time. I ran into this same error when missing the cryptojFIPS.jar. Check the Developer Guides and verify everything needed is available at run time.
FOUND IT!!!
My application is written in Eclipse, and launching from within Eclipse everything worked correctly. When exported as a runnable JAR, the above error popped up.
Solution: export your runnable JAR choosing the following option:
Copy required libraries into a sub-folder next to the generated JAR
Revealing message within the error stack has been the following:
Caused by: com.rsa.crypto.CryptoException: java.lang.SecurityException: java.lang.SecurityException: Toolkit not encapsulated by a jar.
