Beginner here, so please bear with me, ive searched and searched
I have multiple variables for a field that im trying to link to 3 separate catagories using wildcards
Im able to do it for one:
=If Match([Id];“RCP*”) Then “Location1”
I need the correct syntax for multiple ids AND multiple locations
Thank you in advance
scotty24 (BOB member since 2009-01-28)
Try this.
=If(Match([Id];"RCP*";"Location1";If(Match([Id];"AAA*";"Location2";"Location3"))
P.S: Welcome to B
B!
And replace AAA* by your own condition.
Jansi
(BOB member since 2008-05-12)
Thank you!
That worked, now i just need add an “or” to location1 for example
RPC* or ABC* would would then “location1”
Hi Scotty,
You can use this
=If(Match([Id]="RCP*" OR Match([Id]="ABC*" ;"Location1";If(Match([Id];"AAA*";"Location2";"Location3"))
[/code]
GNK_BO (BOB member since 2007-07-17)
Thank you!
Hey scotty,
Was that what you were trying to do?
It is but im getting errors on the syntax.
This works:
=If(Match([Id];“RCP*”);“loc1”;If(Match([Id];“WHP*”);“loc2”;If(Match([Id];“MHT*”);“loc3”; “NA”)))
However when i try to incorporate the OR, i get syntax errors that leave me in a world of confusion
Hey Scotty,
Here is the result for which I tested what you were trying to obtain.
Table has 3 columns Empno,Empname,Name Match.
If Empname starts with A or J it should display Name starts with A/J
If Empname starts with S or T it should display Name starts with S/T
If Empname starts with other than this A,J,S,T it should display Others
So created the variable
Name Match=If(Match([Ename];"A*") Or Match([Ename];"J*");"Name starts with A/J";If(Match([Ename];"S*") Or Match([Ename];"T*");"Name starts with S/T";"Others"))
Attached screen shot shows the results.
Hope this helps.
Correct Syntax for multiple if Match statement -Report l.doc (26.0 KB)
Worked great, thank you so much!
