I can able to login to the application fine, but when I tried to open the corporate document its timing out ,
Can anybody tell me why it is timing out,
Waiting for quick response.
Nirmal
NirmalKumar.S (BOB member since 2006-01-13)
Nirmal
You’ll have to tell us a bit more information about your setup.
One thought – Is your document domain on the same server, using the same connection information as the BOMain.key / security domain? If not – is it possible that you have a firewall rule that’s preventing you from getting to the document domain database / tables?
Otherwise, you’re going to have to tell us anything relevant about your setup that might help someone have a clue.
Anita Craig
(BOB member since 2002-06-17)
