Copy Personal Webi documents from 6.1 to 6.5 (separate srvr)
How can I copy the Webi reports that have been created on Webi 6.1 to a separate server that has Webi 6.5?
I have located the documents under the $INSTALLDIR/nodes///storage/mail/
How can I move this over so that 6.5 can recognize it? If I copy paste in corresponding folder nothing happens. There is some index file that needs to be changed…
chiragk :us: (BOB member since 2003-10-22)
Copy all the WID files from 6.1 and put them on share drive so that you can access from the othere server where 6.5 configured. Then go to 6.5 server and access the shared drive and copy all the WID files and paste into nodes folder on the server…
Hope this helps.
Mohammad
Mohammad T. Hussain (BOB member since 2004-09-21)
