Copy of Universe
I have to build one Universe which should have a copy (exact duplicate with some minor changes) and both of them should point to different database connections.
I have already started working on one Universe. Now, how should i create a duplicate of the Universe (with different name) and have it on the same environment (These two Universes will exists on same Infoview platform)?
Smith85 (BOB member since 2009-12-10)
Using Save As, .unv will create a “copy” with a new CU ID.
You can then re-point this copy to a new connection.
I believe copying to a new folder from within Designer, itself, does this, also.
As they are almost identical, have you considered having one universe and using connection over rides, depending on user group(s)?
Thanks for your quick reply Mak.
So, I won’t change anything in Universe Parameters property (name or something) and I can just click on ‘Save As’, give a different name and it will get saved (and will have different CUID).
Will I have to change the name within Parameter Property fore the new Universe? I am sorry, I am slightly confused by the name I will put during ‘Save As’ and the name in Universe Parameter properties :frowning:
I will do this ‘Save As’ operation in Designer I guess? or should I used CMC? I actually thought doing ‘Save As’ breaks the links between Universe and existing reports.
:!: Careful here, so you want the original reports to work, i.e. you need the CUID to be the same?
Sorry, I didn’t get that bit :).
Please provide further details of the scenario and what you want to achieve?
I think a connection over ride, may be worth looking into?
Alright, I will try to explain this.
I have a Universe and I have some three reports built over it. Now, this Universe points to a database connection (say D1). Now, I want to create an exact duplicate of this Universe using some different connection (say D2) and will have different reports over it.
Basically, the Universe I am currently developing, I need to create a duplicate of it. Both the Universes should have different names and will remain within the same Infoview environment and will have their own reports.
I am slightly confused between the name that we put in Universe Parameters and the name we put during ‘Save As’. I just have access to Designer and not CMC. Although I can suggest for connection override, I have to explore the way to duplicate existing Universe, while keeping the report connection alive (at least for my understanding :slight_smile: )
Hope this helps.
Hope this might help
koundinya17 (BOB member since 2010-11-18)
