Copy Dataproviders
Hi all,
Is there any way to copy a data providers from 1 report to another report provided that the universe remains the same?
tik :india: (BOB member since 2004-09-01)
Check out the download categroy on this forum
dessa :madagascar: (BOB member since 2004-01-29)
Not natively. In V6, you can use one data provider as the starting point for another, but only in the same document. As dessa suggested though, there is a utility here that will copy across documents.
