this little addin for BO Classic, does anyone know where to get it from?
Its the function that allows a data provider to be duplicated with a couple of clicks. Very usefull & time saving!
zito (BOB member since 2006-07-18)
realised there was a download section just after I hit ‘Post’
Doh!
PLEASE REMOVE THIS TOPIC
It is better to keep the topic as the other BOBers may find it using BOB’s search when they will search for this add-in too. ![]()
Marek Chladny
(BOB member since 2003-11-27)
In version 6.5 SP3 (I don’t know about previous versions), this function is built within BO. The “new data wizard” has the option “Use an existing query to build a new one”. This simply starts a new query, as a copy of a previous one.
So no need for add-ins.
Andy
andy_v
(BOB member since 2006-02-21)
since 6.1.x I think it exists
bernard timbal
(BOB member since 2003-05-26)
Unless you want to copy the data provider between documents. The “Use existing query” only works within a single document.
Dwayne Hoffpauir
(BOB member since 2002-09-19)
